KB4516065 Installation Fails with Error 80092004
2019-09-13T16:27:07+00:00
This is the only patch that is getting an error at installation. I've tried update troubleshooter, standalone install and clearing Software Distribution folder without success. Are others having this issue?
2019-09-14T01:44:19+00:00
Had the same problem. What fixed it was to download these two KBnnnnnn patches from the Windows Update Catalog.
KB4490628  (make sure this one gets installed successfully first)
KB4516065
*************************Links Added By VM July 2, 2021******************************** https://www.catalog.update.microsoft.com/Search.aspx?q=KB4490628
https://www.catalog.update.microsoft.com/Search.aspx?q=KB4516065
88 additional answers
    2019-11-07T02:47:15+00:00
    That worked for me. Thank you so much!
    2019-11-07T02:49:18+00:00
    Thanks for the link. That worked for me!
    2019-11-10T14:58:41+00:00
    Excellent, after lots of troubleshooting, reboots, manual re-installs, disabling av etc... this resolved my problem (Installing the service stack update first), thanks for the advice.
    2019-11-10T23:01:45+00:00
    KB4516065
    Thank you lintekPC!  This worked for me!
