Snip & Sketch add a text box
2019-06-25T20:46:44+00:00
I can draw on a snip, but it is hard to write a note with a mouse.
Can I add a text box and  type a note on a snip?
2019-06-26T08:32:43+00:00
Thank you for writing to Microsoft Community Forums.
I understand that you want to add a text box to type a note on a snip using when using Snip & Sketch. However, I would like to inform that the feature to add a text box is currently not available.
I commend you for noticing this feature not being within Snip & Sketch. We would like to hear your thoughts and suggestions, as there may be other users with a similar requirement. Hence, I would suggest you to post a feedback in Microsoft Feedback Hub so that our developing team can review your suggestions and check if it can be included in the future updates.
Regards,
Nikhar Khare
Microsoft Community - Moderator
268 additional answers
    2023-08-24T13:54:02+00:00
    this is absurd - i've used this feature previously and now its not availalable? this is very poor.
    2023-08-30T15:51:55+00:00
    Just use Microsoft Paint... Windows+Shift+S, open up Paint, paste it in, click the "A" tool for text box... voila
    Not sure why Snip & Sketch hasn't prioritized this, but don't need to worry about it anymore
  3. Deleted
    2023-11-10T12:20:26+00:00
    Oh the generalisation is strong in this one...
