Snip & Sketch add a text box
2019-06-25T20:46:44+00:00
I can draw on a snip, but it is hard to write a note with a mouse.
Can I add a text box and  type a note on a snip?
2019-06-26T08:32:43+00:00
Thank you for writing to Microsoft Community Forums.
I understand that you want to add a text box to type a note on a snip using when using Snip & Sketch. However, I would like to inform that the feature to add a text box is currently not available.
I commend you for noticing this feature not being within Snip & Sketch. We would like to hear your thoughts and suggestions, as there may be other users with a similar requirement. Hence, I would suggest you to post a feedback in Microsoft Feedback Hub so that our developing team can review your suggestions and check if it can be included in the future updates.
Regards,
Nikhar Khare
Microsoft Community - Moderator
268 additional answers
    2022-01-23T20:29:23+00:00
    Just add a text tool! And the following:
    • Arrow
    • Box
    • Circle
    Here is what we need to do:
    Circle things
    Point at things
    Write simple things (e.g. "Add text tool here")
    It is time consuming, frustrating and looks very amateurish to try to write with a mouse cursor. Have a look at my example screen shot!
    Notes:
    See Apple's Preview tool. One thing does what you need.
    We don't need 5 different apps to mark up screen shots - we need one quick, default one that does these. basic. things.
    Thank you for receiving...
    2022-02-16T16:24:39+00:00
    Upvote add a text tool, it's ridiculous that this was overlooked.
    2022-02-22T13:39:17+00:00
    If the ability to add a small text box feature to Snip and Sketch, it would make the app even more useful in an office environment.
    Cheerrs,
    Duncan
    2022-02-22T16:50:35+00:00
    We need this feature! To add text I have to take the snip and put it into a different tool (MS Word, Publisher, etc.), then export it from there. This would be greatly beneficial to add simple text to a snip right in the tool. Thank you!
