Snip & Sketch add a text box
2019-06-25T20:46:44+00:00
I can draw on a snip, but it is hard to write a note with a mouse.
Can I add a text box and  type a note on a snip?
2019-06-26T08:32:43+00:00
Thank you for writing to Microsoft Community Forums.
I understand that you want to add a text box to type a note on a snip using when using Snip & Sketch. However, I would like to inform that the feature to add a text box is currently not available.
I commend you for noticing this feature not being within Snip & Sketch. We would like to hear your thoughts and suggestions, as there may be other users with a similar requirement. Hence, I would suggest you to post a feedback in Microsoft Feedback Hub so that our developing team can review your suggestions and check if it can be included in the future updates.
Regards,
Nikhar Khare
Microsoft Community - Moderator
268 additional answers
    2021-01-21T20:27:56+00:00
    I commend you for noticing this feature not being within Snip & Sketch. i commend you for noticing the obvious.
    i commend you for noticing the sillyness of that sentence.
    Either way - contrary to Microsoft's claim - I doubt anyone at Microsoft actually reads these posts.
    2021-01-21T20:38:52+00:00
    I commend you for commending me for commending  nikhar on the sillyness of his joke post
    2021-01-31T20:12:29+00:00
    I bet MS left this feature out on purpose, because using a keyboard is so legacy. We're all expected to have an MS Surface with a pen. But then why give me a keyboard shortcut to screen capture?? MacOS screen grab utility allows me to type notes, because, I guess, unlike Windows, macOS has never had an identity crisis; it's always been a desktop operating system whereas Windows has been teetering between desktop and touch which has left us with irritations like this.
    2021-02-17T13:43:51+00:00
    This was kind of an important feature. How could they overlook such an important feature, now I have to replace it because I can  no longer send detailed instructions overseas to my collaborators. Using arrows and drawings on the snippet is not enough for detailed instructions.
