Snip & Sketch add a text box
2019-06-25T20:46:44+00:00
I can draw on a snip, but it is hard to write a note with a mouse.
Can I add a text box and  type a note on a snip?
2019-06-26T08:32:43+00:00
Thank you for writing to Microsoft Community Forums.
I understand that you want to add a text box to type a note on a snip using when using Snip & Sketch. However, I would like to inform that the feature to add a text box is currently not available.
I commend you for noticing this feature not being within Snip & Sketch. We would like to hear your thoughts and suggestions, as there may be other users with a similar requirement. Hence, I would suggest you to post a feedback in Microsoft Feedback Hub so that our developing team can review your suggestions and check if it can be included in the future updates.
Regards,
Nikhar Khare
Microsoft Community - Moderator
268 additional answers
    2021-01-12T01:24:10+00:00
    Please add a Text tool to the Snip and Sketch. That is so useful.
    2021-01-15T20:50:43+00:00
    This needs to be added! the simplest of things! add some text to a screenshot WOW Microsoft get with it. making outdated and nonuseful tools!!! Please add this!
    2021-01-21T14:38:41+00:00
    I commend you for noticing this feature not being within Snip & Sketch. i commend you for noticing the obvious.
    2021-01-21T19:49:42+00:00
    i commend you for noticing the sillyness of that sentence.
