Snip & Sketch add a text box
2019-06-25T20:46:44+00:00
I can draw on a snip, but it is hard to write a note with a mouse.
Can I add a text box and  type a note on a snip?
2019-06-26T08:32:43+00:00
Thank you for writing to Microsoft Community Forums.
I understand that you want to add a text box to type a note on a snip using when using Snip & Sketch. However, I would like to inform that the feature to add a text box is currently not available.
I commend you for noticing this feature not being within Snip & Sketch. We would like to hear your thoughts and suggestions, as there may be other users with a similar requirement. Hence, I would suggest you to post a feedback in Microsoft Feedback Hub so that our developing team can review your suggestions and check if it can be included in the future updates.
Regards,
Nikhar Khare
Microsoft Community - Moderator
268 additional answers
    2020-12-23T18:34:04+00:00
    Yes, we need the feature to add text
    2020-12-23T18:39:36+00:00
    Oh for goodness sake !!, this is the lamest response I've ever read !!
    The whole reason for snip n sketch is to cut out page snippets and to mark them up with comments.
    How do Microsoft manage to miss the mark every time.   This is such a basic and obvious requirement for such a tool.
    A car manufacturer wouldn't sell a car without wheels and then say to the customer "I commend you for noticing it has no wheels, please post some feedback to see if enough other customers would also like wheels !"
    FFS !!!
    Thank you for giving me a reason for a good laugh!... laughs are being so scarce in 2020...
    2021-01-02T15:20:40+00:00
    Hi!
    I've found the Snip & Sketch tool to be very useful and easy to use but, I've just noticed the TextBox isn't available now have to attach to PowerPoint just to add Text. Would've made life easier if it were available.
    2021-01-09T21:25:21+00:00
    It makes no sense for there not to be a way to just type some text on a snipping.  For example, you may want to snip a screen shot, circle or draw a box around some part of it, and then, add some notes.
    What! Crazy right? Imagine wanting to add some notes to a screenshot? I know it seems far-fetched.
    In Mac OS, it is trivial to take a screenshot and quickly type some notes on it, so it's not like imagining such a thing is unheard of.
    This feature needs to be added to Snip & Sketch.  Even if you have to change the name of the app to Snip, Sketch & Type.
