Snip & Sketch add a text box
2019-06-25T20:46:44+00:00
I can draw on a snip, but it is hard to write a note with a mouse.
Can I add a text box and  type a note on a snip?
2019-06-26T08:32:43+00:00
Thank you for writing to Microsoft Community Forums.
I understand that you want to add a text box to type a note on a snip using when using Snip & Sketch. However, I would like to inform that the feature to add a text box is currently not available.
I commend you for noticing this feature not being within Snip & Sketch. We would like to hear your thoughts and suggestions, as there may be other users with a similar requirement. Hence, I would suggest you to post a feedback in Microsoft Feedback Hub so that our developing team can review your suggestions and check if it can be included in the future updates.
Regards,
Nikhar Khare
Microsoft Community - Moderator
268 additional answers
    2020-05-11T15:01:44+00:00
    Please do add this! I used Jing before, but i started using this tool in windows only to find out i can't add text. So I went back to using Jing. Seriously, who does your user-market-research? This is like the most important feature in any screenshot program! Nobody thought of adding it?
    2020-05-14T18:57:23+00:00
    that sort of answer doesn't seem very interested in serving the user
    2020-05-26T14:27:32+00:00
    this snip tool is a great and easy tool to use but the added text feature would make snips instantly look and feel more professional. This would be great instead of having to open a different program just so my snips don't look like they were submitted with my kindergarteners homework.
    2020-05-27T01:57:53+00:00
    100%!  Tools are helpful!
    I NEED a text box to use this program as my go-to tool.
