Snip & Sketch add a text box
2019-06-25T20:46:44+00:00
I can draw on a snip, but it is hard to write a note with a mouse.
Can I add a text box and  type a note on a snip?
2019-06-26T08:32:43+00:00
Thank you for writing to Microsoft Community Forums.
I understand that you want to add a text box to type a note on a snip using when using Snip & Sketch. However, I would like to inform that the feature to add a text box is currently not available.
I commend you for noticing this feature not being within Snip & Sketch. We would like to hear your thoughts and suggestions, as there may be other users with a similar requirement. Hence, I would suggest you to post a feedback in Microsoft Feedback Hub so that our developing team can review your suggestions and check if it can be included in the future updates.
Regards,
Nikhar Khare
Microsoft Community - Moderator
268 additional answers
    2020-04-28T19:54:59+00:00
    It is very strange that this program lacks such basic functionality.   SnagIt is a dream compared to this.
    2020-04-28T19:55:52+00:00
    Yes,  SnagIt is absolutely the better app.  It has many additional components, also.
    2020-04-29T00:33:17+00:00
    WE REALLY NEED THIS !!  How else can one annotate what they snip to document what is going on.  Sorry finger drag is not the answer.
    2020-04-29T16:20:01+00:00
    Why would  a design team completely omit the ability to input text in a feature such as Snip & Sketch.
    Where it is utilized to capture/ covey  information. quite possibly needing notation....
    Let hope a little more effort can be dedicated to an otherwise useful utility
