Snip & Sketch add a text box
2019-06-25T20:46:44+00:00
I can draw on a snip, but it is hard to write a note with a mouse.
Can I add a text box and  type a note on a snip?
2019-06-26T08:32:43+00:00
Thank you for writing to Microsoft Community Forums.
I understand that you want to add a text box to type a note on a snip using when using Snip & Sketch. However, I would like to inform that the feature to add a text box is currently not available.
I commend you for noticing this feature not being within Snip & Sketch. We would like to hear your thoughts and suggestions, as there may be other users with a similar requirement. Hence, I would suggest you to post a feedback in Microsoft Feedback Hub so that our developing team can review your suggestions and check if it can be included in the future updates.
Regards,
Nikhar Khare
Microsoft Community - Moderator
268 additional answers
    2020-02-28T18:57:11+00:00
    Microsoft,
    My boy, you mean to tell me I got to use Snip & Sketch to draw on my screenshots and then I got to take that image into Microsoft Paint to put some text on the screenshot?
    Come on my boy! Get real.
  2. Deleted
    2020-03-04T15:23:59+00:00
    Regards,
    Nikhar Khare
    Text would be so useful......
    I use this tool all the time , and let other know how useful it is !!!
    2020-03-09T23:37:12+00:00
    that's super annnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnoooooooooooooooooooooooyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyiiiiiiiiiiiiiiiiiiiiiiiiiiiinnnnnnnnnnnnnnnnnnnnnnnnnnnnnngggggggggggggggggggggggggggggg
