I uninstalled some of latest windows 10 1903 version updates and had the old version of windows ink space back. But the main issue I am experiencing is that screen sketch has been replaced with snip and sketch. Is there anyway I can have screen sketch back?
Sketchpad has completely disappeared from Ink Workspace
I have tried rebooting and turning Ink workspace on and off from settings and taskbar. It is only showing me Whiteboard and Fullscreen snip. Did Windows do away with sketchpad, forcing me to login with a Windows ID to use Whiteboard? Or is this a bug from a recent update? Or is there anything else I can try?
Windows for home | Windows 10 | Windows ink and touch
2019-08-18T17:10:39+00:00 -
2019-08-18T21:23:35+00:00 Thanks for the tip. I wasn't really wanting to bother rolling back, but I'll consider it.
However, I read in some other sites online that they did in fact remove the functionality of the old Ink Workstation in favor of this new, more minimalist approach. Sticky Notes is still there, too.
You just don't see it on the Ink Workstation. It's kind of a bummer, but oh well.
I really don't know who thinks these types of changes are a good idea.
2019-08-19T00:11:00+00:00 However, I read in some other sites online that they did in fact remove the functionality of the old Ink Workstation in favor of this new, more minimalist approach. Sticky Notes is still there, too.
__________________________________________________________________________________
Hi PeteOliva,
You Are Correct, It was revamped In Windows 10 May 1903 Update. Please see my reply to jnossie, Further towards the beginning of this thread.
I Hope This Helps
If My Reply Answered Your Question, Please Mark It Answered. Thank-You
2019-08-19T15:05:06+00:00 I do not have the name from that day, however, the most recent update installed on 8/19/2019 is probably the same one that I deleted. That is KB4507453.
I am a bit confused now because even with this recent update re-installed (the update I believed to be the cause of the problem), WIndows Ink Workspace is back to its regular format.
