Sketchpad has completely disappeared from Ink Workspace
2019-08-08T21:05:51+00:00
I have tried rebooting and turning Ink workspace on and off from settings and taskbar. It is only showing me Whiteboard and Fullscreen snip. Did Windows do away with sketchpad, forcing me to login with a Windows ID to use Whiteboard? Or is this a bug from a recent update? Or is there anything else I can try?
Windows for home | Windows 10 | Windows ink and touch
    2019-11-19T15:52:14+00:00
    You have clearly not even read the issue if you think eather of these links can help.
    I am having the same issue as the original post though the new "white borad" app is drwadfull.
    2019-11-25T14:30:58+00:00
    Where do I complain about this?  As stated by a few others, this little app helped make the Surface Pro useful.  Now if I can't quickly sketch something, I might as well buy a competitive product.
    With all the data you collect Microsoft, didn't you check the usage of this app before you made it disappear?
    2019-11-28T05:42:10+00:00
    Sketchpad was better than whiteboard.  I'm colorblind and whiteboard doesn't even say what the colors are... Pretty pissed.  No wonder people buy apple
    2019-12-12T02:56:53+00:00
    Hey Microsoft, are you listening?
    You screwed up.....AGAIN!
    2019-12-12T03:11:07+00:00
    Anyone that wants to try, Autodesk has a decent FREE program, SketchBook.
    I just put it on.  Seems ok.
