Bluetooth disappered from device manager with "Unknown USB Device (Device Descriptor Request Failed)" -error
2019-06-18T05:47:12+00:00
Hi!
I have some Bluetooth issues with my Asus UX330CAK notebook PC. Yesterday I tried to connect my bluetooth headphones to my computer like I normally would but, after pressing the bluetooth icon in notification center, the bluetooth icon disappeared. I looked it up on device manager, and I didn't find bluetooth there unless I clicked "show hidden devices". Now I can't find the bluetooth in hidden devices anymore. I can't enable bluetooth in settings, there is no bluetooth on switch anymore.
Also I in device manager I have one device in USB devices which has yellow warning sign and says: Unknown USB Device (Device Descriptor Request Failed), error code is 43. I have nothing connected to the USB-ports so I think this can be related for my Bluetooth issue. I have found that some people had their Bluetooth hidden from device manager and had this issue too.
I have searched this particular issue on web and I have found some threads and I tried all the following things to restore my Bluetooth:
  • I ran troubleshooting for Bluetooth, it just said that I dont have bluetooth enabled, I can try to enable it with external adapter.
  • I ran troubleshooting for Hardware and devices and it did show the "Unknown USB Device (Device Descriptor Request Failed)" issue, but didn't fix it.
  • Also, I tried to troubleshooters for network adapters and windows update but they didn't find any issues.
  • I've tried SFC /scannow and DISM.exe but they didn't find any issues.
  • I have just updated newest Windows version, and I have tried install windows again, but the issue still persists.
  • I have tried to uninstall "Unknown USB Device (Device Descriptor Request Failed)" and also uninstall my main usb driver, but that didn't fix it.
  • I installed correct Bluetooth and network adapters from Intel's site and I also tried to delete them from installer and install again, but that didn't fix it too.
-  I Installed also Intel's driver updater but that didn't solve my issue. I tried to use 3rd party dirver updaters and they didn't fix my Bluetooth and I tried to also clean my registry with CCleaner.
  • Also I tires tried to fully drain my battery and restart my laptop but even that didn't fix my issue.
Is there any other things to try or could the error be hardware related?
I apologise for any grammar errors, English isn't my native language.
Best regards,
Elias
2019-08-28T15:04:37+00:00
Andre's reply is a bit disappointing as he thanked somebody last year for providing a solution to this issue that worked for the requester and has also just worked for me:
https://answers.microsoft.com/en-us/windows/forum/all/bluetooth-not-working-usb-device-descriptor/2af8f09f-ce33-47f8-a42a-1b55e8cf60fd
The problem is that your system is not recognising the Bluetooth chip and thinks it is unplugged and it is seeing an unknown device that is not communicating correctly.
A simplified version is as follows (I found that it was not necessary to drain the laptop battery completely):
  1. Perform a hard shut-down by holding the shift key is held down whilst selecting Windows Shut Down
  2. Ensure your computer is unplugged
  3. Hold down the power key for 93 seconds. That's 90, which is the maximum recommended elsewhere plus 3 to make sure it is over 90!
  4. Press the power key briefly to start your computer
  5. Allow it to start fully.
If you open Device Manager (e.g. right click Windows Key -> Device Manager or from the Control Panel), you should now see that the Bluetooth section has reappeared and there are no Unknown USB devices in the USB section. This means that your Bluetooth is now working again.
This apparently works by disconnecting the power (even residual power) from relevant chips which mean that they re-establish communications from scratch when you restart.
50 additional answers
    2021-03-09T03:00:30+00:00
    I have had the same issue and while performing the hard shut down does bring back the bluetooth in the device manager, it's only temporary. As soon as my laptop sleeps or hibernates, it's back to the unknown USB Device and error Code 43 - Windows has stopped this device because it has reported problems.
    Do you know of a way to fix the core problem of the pc not recognizing the chip?
    2021-03-10T05:00:50+00:00
    it worked sir thank you!...but it happened again....Is it okay to follow your steps over and over again when this happen?
    2021-03-10T05:03:14+00:00
    I Have the same problem Sir.
    2021-03-27T03:01:00+00:00
    Signed in just to say that this worked when nothing else would. This was literally going to be the last thing I tried before sending it to a computer repair place to fix the issue. THANK YOU SO MUCH!
