Constant BSOD Issues
2019-07-31T23:05:50+00:00
I have a custom built PC and since Day 1 I have had issues with BSOD's.  Usually this happens while playing a game, but has happened just sitting idle.  I am not a PC technical guy but I need some help to fix this issue.  I never get a specific fault in the Bluescreen, but the Bluescreen Viewer point to ntoskrnl.exe as the culprit but in my research its never the actual fault.
The Following are the BSOD's I am getting:
Security Kernel Check Failure (Most Frequent)
System Service Exemption
IQRL not Less or Equal
The Build Is as Follows:
Asus Prime Z390-A
Intel I7-8700
32 GB Corsair Ram
Nvidia GeForce RTX 2070
Corsair MP510 SSD
Windows 10 Pro 1903
Following has already been done:
Reinstalled Win 10 multiple times
Uninstalled and reinstalled Graphics Drivers
Updated all drivers that needed updated (done by going thru device manager one at a time)
chkdsk, memtest, sfc, to name a few
Tried different ram, both amount and brand
3 Different HD's, both brand and SSHD, SSD, and Standard HD
Im not 100% sure what info is needed but ask and Ill do my best.  Please HELP!
    2019-08-04T12:30:35+00:00
    That's what Im trying to say there isn't a even a folder to share.  I don't have a folder that I can find to compress anywhere on my pc.
    2019-08-05T12:55:28+00:00
    Apologies for being vague. Right click the desktop>New Compressed folder.
    Drag and drop the file in the folder you just created.
  3. Deleted
    2019-08-06T00:27:59+00:00
    This might be it but I Honestly have no idea....
    https://1drv.ms/u/s!AhoUalcrbFFVj1F0cHnXiH\_AnHxF?e=pz9pqz
    2019-08-06T00:40:26+00:00
    I hope these are correct and its what you are looking for....this is the second BSOD in the past 5 minutes.
    https://1drv.ms/u/s!AhoUalcrbFFVj1LGO7iGbSIC9JaV?e=t0NMuE
