Constant BSOD Issues
2019-07-31T23:05:50+00:00
I have a custom built PC and since Day 1 I have had issues with BSOD's.  Usually this happens while playing a game, but has happened just sitting idle.  I am not a PC technical guy but I need some help to fix this issue.  I never get a specific fault in the Bluescreen, but the Bluescreen Viewer point to ntoskrnl.exe as the culprit but in my research its never the actual fault.
The Following are the BSOD's I am getting:
Security Kernel Check Failure (Most Frequent)
System Service Exemption
IQRL not Less or Equal
The Build Is as Follows:
Asus Prime Z390-A
Intel I7-8700
32 GB Corsair Ram
Nvidia GeForce RTX 2070
Corsair MP510 SSD
Windows 10 Pro 1903
Following has already been done:
Reinstalled Win 10 multiple times
Uninstalled and reinstalled Graphics Drivers
Updated all drivers that needed updated (done by going thru device manager one at a time)
chkdsk, memtest, sfc, to name a few
Tried different ram, both amount and brand
3 Different HD's, both brand and SSHD, SSD, and Standard HD
Im not 100% sure what info is needed but ask and Ill do my best.  Please HELP!
    2019-08-02T23:41:52+00:00
    2019-08-02T23:43:18+00:00
    2019-08-03T04:14:38+00:00
    Since you renamed GLCKIO2.sys to GLCKIO2.sys.old, it lost its properties.
    With this screenshot, I wanted to know who is the manufacturer of this driver.
    Anyway, when you next BSOD, post the dump file here.
    2019-08-03T05:04:09+00:00
    Digital signature says its ASUStek computer Inc.
    but also says Microsoft Windows Hardware Compatibility Publisher
    2019-08-03T07:22:22+00:00
    Check what all utilities of Asus you have. I am not sure which utility provides this particular driver.
    For the time being, hold on. Let's wait for BSOD to occur again and see if this particular driver is named again.
