I've the same problem, after the update form 1809 to 1903 my Creative Audigy 2 ZS don't work
update 1903 sound problem
I have just updated to 1903, and have lost all sound. I have a Creative Audigy2 ZS Pro, yes, I know it's old, but it was working perfectly on build 1809.
After this 1903 update, no sound, so I went back to 1809, and hey presto, I got my sound back. I then tried the very latest 1903 build, but lost the sound again. Have MS got an answer? I will have to go back to 1809 if I want to hear anything, but can wait a day or so if anyone at MS can give me a solution.
2019-05-06T06:22:44+00:00 -
2019-05-10T17:07:17+00:00 I have the same with with my Creative SB Audigy 2 ZS. Yesterday, I upgraded from Windows 1809 to 1903 from though the "Windows Insider Program" in order to get access to the new Windows Terminal.
2019-05-11T16:31:28+00:00 I tried many drivers from Creative, DanielK, even PAX : No result.
No problem found by problem resolver.
But, all creative audio inputs and outputs in device manager are not migrated due to partial or ambiguous match !
Internal Realtek is OK.
2019-05-16T07:09:21+00:00 I have found a solution.
Just download the offical Audigy RX driver from Creative website.
Extract it with Winrar or other tool. Manually install the driver from the folder Audio -> DriversWin10 -> wdm -> browse wdm_emu.inf file.
If installed succesfully, then just restart the PC.
Step 2.
Download the Audigy Support Pack from https://drive.google.com/file/d/0B4veZnyFbxW4VjdhUVMzOG1yVFE/view, or from the website: http://danielkawakami.blogspot.com/2017/01/sb-audigy-series-support-pack-62.html
Extract it. Then run Setup. Choose Custom install. Uncheck the Driver. Install all other App. Restart PC, and Audigy 2 ZS is working.
All apps working. Speaker Settings, EAX Console, Audio Console
2019-05-16T08:12:51+00:00 Excellent work!!
It works with my Audigy4 as well but as I did not have the option for a custom install what I did is to first install the Audigy 6.2 support pack, reboot then in the device manager I deleted the driver (check delete driver files), reboot and then I installed the extracted large RX driver by right-clicking in the wdma_emu.inf in the DriverWin10 file and saying install
Windows 10 1903 with the 113 CU
