Is there any way to fix this issue with an Sound Blaster Audigy Platinum EX? I followed instructions here but nothing seems to be working, this card with the box was working fine until I updated this week to 1903 , I thought the issue was solved so I upgraded and now I don't have audio anymore , any other advice?
update 1903 sound problem
I have just updated to 1903, and have lost all sound. I have a Creative Audigy2 ZS Pro, yes, I know it's old, but it was working perfectly on build 1809.
After this 1903 update, no sound, so I went back to 1809, and hey presto, I got my sound back. I then tried the very latest 1903 build, but lost the sound again. Have MS got an answer? I will have to go back to 1809 if I want to hear anything, but can wait a day or so if anyone at MS can give me a solution.
Deleted
Deleted
Deleted
2020-11-25T11:18:06+00:00 -
2021-01-25T20:03:17+00:00 I'm interested in this bit that you wrote "and using autoruns i've removed entries in drivers and services related to creative. "
becuz. windows is not letting me uninstall the driver ( keeps crashing ).
what is the autoruns feature you speak about. thanks.
