Infrared not recognized
2019-05-22T19:34:31+00:00
Upgraded to Windows 10 ver 1903 and the infrared device is not working. Got this:
Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. (Code 19)
2019-06-19T21:33:58+00:00
Dalvic do you still have the problem?
Try to remove and re-add the Infrared.  It is probably more reliable to use the PowerShell Commands (If you are not comfortable you can try the interface which may not work.
Power Shell to Add / remove IrDA infrared components
Run PowerShell as administrator
Query state of the IrDA components:
get-WindowsCapability -online -Name "Network.Irda~~~~0.0.1.0"
Unistall
Remove-WindowsCapability -online -Name "Network.Irda~~~~0.0.1.0"
Add
add-WindowsCapability -online -Name "Network.Irda~~~~0.0.1.0"
An example of the results (Thanks to FritzMerkel) of the scripts when fixing IrDA issue.
PS C:\WINDOWS\system32> get-WindowsCapability -online -Name "Network.Irda~~~~0.0.1.0"
State        : NotPresent
DisplayName  : IrDA infrared
Description  : Support for IrDA devices. Requires special IrDA hardware.
DownloadSize : 604101
InstallSize  : 1236233
Then the others:
PS C:\WINDOWS\system32> Remove-WindowsCapability -online -Name "Network.Irda~~~~0.0.1.0"
Path          :Online        : TrueRestartNeeded : False
PS C:\WINDOWS\system32> add-WindowsCapability -online -Name "Network.Irda~~~~0.0.1.0">>
Name         : Network.Irda~~~~0.0.1.0State        : InstalledDisplayName  : IrDA infraredDescription  : Support for IrDA devices. Requires special IrDA hardware.DownloadSize : 604101InstallSize  : 1236233
Alternative: on windows interface:
To remove:
Go to Settings -> Apps and Features -> Optional Features
Select IrDA Infrared and click uninstall.
To Install
Add a feature (top of list)
Select IrDA Infrared from the list.
It installs and should be visible in the Optional Features list.
Go back to Control Panel\All Control Panel Items and hopefully you will now see Infra Red icon and features.
If this does not work do use the PowerShell commands
77 additional answers
    2019-06-16T19:36:52+00:00
    I think maybe you did find the fix....but I'd already done the clean install.
    Reloaded 1903 UPGRADE. No IrDA in Control Panel
    Ran the Powershell commands you suggested:
    State        : NotPresent
    Then the others:
    **Went and checked Control Panel >>>> IrDA present!!**Plugged in dongle, appeared in Device Manager, indicates 'working properly'.
    Tested with both download programs >>>> WORKED!
    Interesting how Powershell worked, and the Adding in APPS did not.
    Also interesting that Powershell returns different info in 1809 and 1903.
    Maybe something bears checking there?
    2019-06-16T20:57:59+00:00
    Great news.  I hope that works correctly and consistently.
    Regarding your comments:
    "Interesting how PowerShell worked, and the Adding in APPS did not." - Interesting is the correct word, but I have seen this on a number of occasions over the last 20 years.  If PowerShell works and the interface doesn't the solution is PowerShell.  :)  This is the world of Microsoft...
    "Also interesting that Powershell returns different info in 1809 and 1903" - As we are querying specifically the IrDA component by name clearly the name changed between 1809 and 1903 so it is not seen; but I suspect it is a completely new add-on feature in 1903.  this does not concern me but somebody with access to detailed information would be needed to confirm my suspicions.
    FYI: running "get-WindowsCapability -online" shows all components and their status.  I could not find an IrDA on 1809 on my computer.
    2019-06-19T22:25:11+00:00
    Used the "Settings" method and it worked!!! Thanks a bunch!!!
    2019-06-22T05:57:17+00:00
    I have 3 windows machines with 1903. One on the Insider fast channel and two using normal updates
    The ones with the normal consumer level worked fine with the USB adapter after 1903
    The one in fast channel not and got driver exclamation mark with the error description that registry was damaged.
    Because of this, re-installled Windows 1903. Once using reparing PC, the 2nd time time fresh form USB drive.
    Both failed and the same exclamation mark shown. This was two weeks ago.
    i compared the registry from good and bad machine and found in the bad machine many registry entries were gone
    Also two IrDA related driver files were missing compared to the good units
    After copying the registry settings and files to the bad machine, Still the registry error persisted
    Today tried again with the same USB drive from two weeks ago. This time a a different result
    After installing fresh,  the device was shown as "unknown "device.
    click "update driver"
    After a long wait of 5 (!) minutes the loading Window timed out with the messages:
    "Windows encountered a problem installing the drivers for your device"
    "Windows found driver for your device but encountered an error while attempting to install them"
    "USB-infrared Adapter"
    "The operation returned because of the timeout period expired"
    "if you know the manufacturer of your device, you can visit their website and check the support section for drivers"
    In my case this was the Coolgear. Infrared adapter.
    After pulling a few hairs out,  found this post and fixed it.
    Reinstaling all software again...
    This is the second time Windows 10 causes IR problems for unneeded reasons. First by removing the whole IR stack (after it worked in earlier updates) and now again breaking the driver installation in 1903.
    This is extremely annoying. Several people reported this issue.
    Please fix this as soon as possible and add this as a mandatory test case before releasing another update.
    Thank you.
