Infrared not recognized
2019-05-22T19:34:31+00:00
Upgraded to Windows 10 ver 1903 and the infrared device is not working. Got this:
Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. (Code 19)
2019-06-19T21:33:58+00:00
Dalvic do you still have the problem?
Try to remove and re-add the Infrared.  It is probably more reliable to use the PowerShell Commands (If you are not comfortable you can try the interface which may not work.
Power Shell to Add / remove IrDA infrared components
Run PowerShell as administrator
Query state of the IrDA components:
get-WindowsCapability -online -Name "Network.Irda~~~~0.0.1.0"
Unistall
Remove-WindowsCapability -online -Name "Network.Irda~~~~0.0.1.0"
Add
add-WindowsCapability -online -Name "Network.Irda~~~~0.0.1.0"
An example of the results (Thanks to FritzMerkel) of the scripts when fixing IrDA issue.
PS C:\WINDOWS\system32> get-WindowsCapability -online -Name "Network.Irda~~~~0.0.1.0"
State        : NotPresent
DisplayName  : IrDA infrared
Description  : Support for IrDA devices. Requires special IrDA hardware.
DownloadSize : 604101
InstallSize  : 1236233
Then the others:
PS C:\WINDOWS\system32> Remove-WindowsCapability -online -Name "Network.Irda~~~~0.0.1.0"
Path          :Online        : TrueRestartNeeded : False
PS C:\WINDOWS\system32> add-WindowsCapability -online -Name "Network.Irda~~~~0.0.1.0">>
Name         : Network.Irda~~~~0.0.1.0State        : InstalledDisplayName  : IrDA infraredDescription  : Support for IrDA devices. Requires special IrDA hardware.DownloadSize : 604101InstallSize  : 1236233
Alternative: on windows interface:
To remove:
Go to Settings -> Apps and Features -> Optional Features
Select IrDA Infrared and click uninstall.
To Install
Add a feature (top of list)
Select IrDA Infrared from the list.
It installs and should be visible in the Optional Features list.
Go back to Control Panel\All Control Panel Items and hopefully you will now see Infra Red icon and features.
If this does not work do use the PowerShell commands
77 additional answers
    2019-06-15T08:36:21+00:00
    What solved it for me was disconnecting the IrDA device from the computer, then followed all the steps in smile's reply, I extracted the ASIX drivers 1.3.2.0 to a folder and manually installed them by right clicking "MosUIr64.INF" and select "Install".
    After the reboot I plugged in the USB IrDA adapter and it worked again.
    You migh try this even though it's for an older version of Windows 10 https://support.microsoft.com/sv-se/help/3150989/an-irda-networking-device-does-not-work-in-windows-10-version-1511 , then you can clearly see if the IrDA service is actually running by using the command "sc query irda".
    2019-06-15T18:38:54+00:00
    I have the generic silver adapter. It looks just like the Polar Silver adapter and has worked fine for years....until this update. Both the black and the silver seem to be USB 1.1.
    Where do you get drivers? They always simply loaded, or loaded with [Windows Update].
    Searching for ASIX USB drivers get all those annoying commercial driver update subscription. The ASIX.tw site is not helpful.
    2019-06-15T18:53:00+00:00
    FritzMerkel:
    If you are talking about the  IRDA Infrared Add-on if it is not proposed in the windows add on as originally described; I am still trying to understand how to force a removal or activation.  .
    If it for the USB dongle: I would always advise to use the drivers from the manufacturer.  If you still have the drivers, use the windows 8 or windoiws 7 drivers that correspond to the version of windows 10 you are running.
    Windows 10 64 bit use Windows 8 or windows 7 drivers with the 64 or x64 suffix.
    Windows 10 32 bit (unlikely) Windows 8 or windows 7 drivers with a 32 suffix or no suffix.
    2019-06-15T20:59:35+00:00
    More info, some good, some bad.
    Reinstalled Win10x64Pro_1903 CLEAN, no upgrade.
    Used the method in [smiles post] above to add IrDA > It showed up in Control Panel this time. (It did not with the upgrade.
    Plugged in 'silver bullet/generic IrDA dongle' > showed up in Device Manager, no driver
    Right clicked setting > find driver update online > It did > Installed > looked like it was installed properly.
    Installed Smarttrak ver 2081 (current version on ScubaPro) > loaded > rebooted.
    Tried to open Smarttrak > FAILED with those 'useful' error messages Windows provides (failure to open at module #^#@#$@)
    Did a BUNCH of attempts to 'troubleshoot' and emulate using an older version of Windows. None worked. ALL give the same error messages.
    Installed Subsurface > IrDA worked fine and Aladin Tec 2G downloaded properly.
    Not sure where to go from here.
    Upgrade > IrDA breaks. Clean install > Program breaks.
    I think MS needs to do some work on the IrDA module in 1903.
