Infrared not recognized
2019-05-22T19:34:31+00:00
Upgraded to Windows 10 ver 1903 and the infrared device is not working. Got this:
Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. (Code 19)
2019-06-19T21:33:58+00:00
Dalvic do you still have the problem?
Try to remove and re-add the Infrared.  It is probably more reliable to use the PowerShell Commands (If you are not comfortable you can try the interface which may not work.
Power Shell to Add / remove IrDA infrared components
Run PowerShell as administrator
Query state of the IrDA components:
get-WindowsCapability -online -Name "Network.Irda~~~~0.0.1.0"
Unistall
Remove-WindowsCapability -online -Name "Network.Irda~~~~0.0.1.0"
Add
add-WindowsCapability -online -Name "Network.Irda~~~~0.0.1.0"
An example of the results (Thanks to FritzMerkel) of the scripts when fixing IrDA issue.
PS C:\WINDOWS\system32> get-WindowsCapability -online -Name "Network.Irda~~~~0.0.1.0"
State        : NotPresent
DisplayName  : IrDA infrared
Description  : Support for IrDA devices. Requires special IrDA hardware.
DownloadSize : 604101
InstallSize  : 1236233
Then the others:
PS C:\WINDOWS\system32> Remove-WindowsCapability -online -Name "Network.Irda~~~~0.0.1.0"
Path          :Online        : TrueRestartNeeded : False
PS C:\WINDOWS\system32> add-WindowsCapability -online -Name "Network.Irda~~~~0.0.1.0">>
Name         : Network.Irda~~~~0.0.1.0State        : InstalledDisplayName  : IrDA infraredDescription  : Support for IrDA devices. Requires special IrDA hardware.DownloadSize : 604101InstallSize  : 1236233
Alternative: on windows interface:
To remove:
Go to Settings -> Apps and Features -> Optional Features
Select IrDA Infrared and click uninstall.
To Install
Add a feature (top of list)
Select IrDA Infrared from the list.
It installs and should be visible in the Optional Features list.
Go back to Control Panel\All Control Panel Items and hopefully you will now see Infra Red icon and features.
If this does not work do use the PowerShell commands
77 additional answers
    2019-06-14T15:42:42+00:00
    Thanks!
    This solved my problem with Polar IrDA USB adapter and Windows 10 1903.
    2019-06-14T16:15:05+00:00
    Im still getting a code 19 error.
    2019-06-14T17:47:02+00:00
    Dalvic
    Do you have the InfraRed section in Control Panel under All Control Panel Items?
    • If this is not there clearly the IrDA stack / service is not installed and there is nothing for the Dongle to connect to even though the drivers will install correctly the device will not start up and be seen in error in device manager.
    What happens if you try the advice in section 1 to Install the IrDA service?
    Once IrDA is seen in the control panel it is time to remove / reinstall the device drivers for the Dongle.
    2019-06-14T18:06:52+00:00
    I see the infrared device in Device Manager in the Control Panel but I get a code 19.  I have uninstalled the device driver rebooted and it finds a device driver and give the same code 19.  I have tried to load the device driver from a usb drive but I get a message that the best driver is installed (but still the code 19).
