Infrared not recognized
2019-05-22T19:34:31+00:00
Upgraded to Windows 10 ver 1903 and the infrared device is not working. Got this:
Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. (Code 19)
2019-06-19T21:33:58+00:00
Dalvic do you still have the problem?
Try to remove and re-add the Infrared.  It is probably more reliable to use the PowerShell Commands (If you are not comfortable you can try the interface which may not work.
Power Shell to Add / remove IrDA infrared components
Run PowerShell as administrator
Query state of the IrDA components:
get-WindowsCapability -online -Name "Network.Irda~~~~0.0.1.0"
Unistall
Remove-WindowsCapability -online -Name "Network.Irda~~~~0.0.1.0"
Add
add-WindowsCapability -online -Name "Network.Irda~~~~0.0.1.0"
An example of the results (Thanks to FritzMerkel) of the scripts when fixing IrDA issue.
PS C:\WINDOWS\system32> get-WindowsCapability -online -Name "Network.Irda~~~~0.0.1.0"
State        : NotPresent
DisplayName  : IrDA infrared
Description  : Support for IrDA devices. Requires special IrDA hardware.
DownloadSize : 604101
InstallSize  : 1236233
Then the others:
PS C:\WINDOWS\system32> Remove-WindowsCapability -online -Name "Network.Irda~~~~0.0.1.0"
Path          :Online        : TrueRestartNeeded : False
PS C:\WINDOWS\system32> add-WindowsCapability -online -Name "Network.Irda~~~~0.0.1.0">>
Name         : Network.Irda~~~~0.0.1.0State        : InstalledDisplayName  : IrDA infraredDescription  : Support for IrDA devices. Requires special IrDA hardware.DownloadSize : 604101InstallSize  : 1236233
Alternative: on windows interface:
To remove:
Go to Settings -> Apps and Features -> Optional Features
Select IrDA Infrared and click uninstall.
To Install
Add a feature (top of list)
Select IrDA Infrared from the list.
It installs and should be visible in the Optional Features list.
Go back to Control Panel\All Control Panel Items and hopefully you will now see Infra Red icon and features.
If this does not work do use the PowerShell commands
77 additional answers
    2019-08-24T17:48:47+00:00
    To remove:
    To Install
    Man-O-Man.......If we are ever on a dive boat or trip together, I wanna buy you a beer or whatever your favorite beverage may be.  Works like a champ now.  You da man!!!!!!
    2019-09-20T06:20:39+00:00
    Hi {smile}.  Have you tried this again recently (Sep 2019)?  I also have a UWatec IR adapter.  It was working.  The previous process with the "add-On" worked fine and when the dongle was plugged in, Windows would pop up the "InfraRed device" notification.  A recent update broke the process.  So I did the usual uninstall and reinstall processes for the Add-On.  Now when I plug it in, Device Manager shows "STIr42xx" which does not work and is not recognized by pretty well anything.  The InfraRed icon is shown in Control Panel.  When I open the module, it shows OK for settings (make sense), but all of the fields in the hardware tab are blank ... no comms with the dongle.
    So the short question is have you tried the InfraRed interface in the past few weeks after the recent updates?
    2019-09-20T06:24:42+00:00
    Hi {smile}, have you tried this in the past few weeks (Sep 2019) as it would appear that a recent update has damages this capability (again)?
    2019-09-20T07:05:02+00:00
    Just to add to the thread, I "successfully" (according to Windows) uninstalled and installed InfraRed.  But I note it still present in Control Panel.  So I ...
    State        : NotPresent
    Path          :
    Online        : True
    add-WindowsCapability : Element not found.
    At line:1 char:1
    • add-WindowsCapability -online -Name "Network.Irda~~~~0.0.1.0"
        + CategoryInfo          : NotSpecified: (:) [Add-WindowsCapability], COMException
        + FullyQualifiedErrorId : Microsoft.Dism.Commands.AddWindowsCapabilityCommand
    It still shows as installed in Control Panel and it still does not work!
    Any thoughts?
