Creative SB Audigy 2 ZS driver issue - NO SOUND- after Windows 1903 update
2019-04-30T16:57:58+00:00
Just updated to 1903, and have lost all sound,I know it's old soundcard, but it was working perfectly on build 1809/1803/1709/1703/1607..
2019-06-02T20:38:50+00:00
Hi!
This worked for my Creative Audigy 2 ZS and Windows 10 1903 update:
https://extreme.pcgameshardware.de/windows-7-8-1-und-10-windows-allgemein/540331-win-10-update-1903-soundblaster-kein-ton.html?highlight=audigy
Download "Audigy RX Driver" from Creative
Extract all files
Go to the folder "Audio\DriversWin10\wdm"
Right-click "wdma_emu.inf" and select "install"
Restart and enjoy!
Best regards!
Markus
73 additional answers
    2020-09-22T16:26:32+00:00
    I finally have sound in windows 10 x64 version 2004, I already thought sadly that I could not use my card. With previous versions of win10 if it works with the creative driver for windows 7 x64. Thank you very much, the solution was simple and effective. :)
    2020-10-11T22:07:05+00:00
    Hello!
    Take a look at Daniel_K 's blog, as he has released some new drivers recently.. maybe you can try fiddling with those?
    2020-12-18T12:49:39+00:00
    where do I find the extracted files?
    Thanks in advance.
    2020-12-24T08:08:30+00:00
    Thanks in advance.
    Hello Joris
    I use Sound blaster Audigy II and II ZS now in December work 100% Eax Console, Control Panel All Normaly and Sound Very Very Good...
