Creative SB Audigy 2 ZS driver issue - NO SOUND- after Windows 1903 update
2019-04-30T16:57:58+00:00
Just updated to 1903, and have lost all sound,I know it's old soundcard, but it was working perfectly on build 1809/1803/1709/1703/1607..
2019-06-02T20:38:50+00:00
Hi!
This worked for my Creative Audigy 2 ZS and Windows 10 1903 update:
https://extreme.pcgameshardware.de/windows-7-8-1-und-10-windows-allgemein/540331-win-10-update-1903-soundblaster-kein-ton.html?highlight=audigy
Download "Audigy RX Driver" from Creative
Extract all files
Go to the folder "Audio\DriversWin10\wdm"
Right-click "wdma_emu.inf" and select "install"
Restart and enjoy!
Best regards!
Markus
73 additional answers
    2019-04-30T17:00:38+00:00
    Hello, I am an independent consultant willing to help.
    Thank you for publishing your question, please open the following Microsoft thread where you will be presented with all the information and a permanent solution to your problem, follow the steps and instructions that appear there:
    https://answers.microsoft.com/en-us/windows/for... one
    This is the link that is provided there
    Problem with the Creative SB Audigy 2 ZS driver: NO SOUND, after the Windows 1903 update
    I hope this information solve your problem, I will be attentive to any comments.
    Best regards,
    Cristhian
    2019-05-21T14:49:39+00:00
    "Permanent solution"? No, you linked to a thread that said "go check Creative Labs' support site." The issue still persists, the 1903 update breaks Audigy 2 playback, and while the card is old, there was no indication that audio playback would be broken after the 1903 update.
    2019-06-06T09:26:58+00:00
    It's Work !!!!!!!!!!!!
    Thanks a lot.
    2019-06-15T02:39:30+00:00
    It works for me. Thanks!
    "Creative Audigy 2 ZS and Windows 10 1903 update"
