Please upload latest minidumps.
:( Your PC ran into a problem and needs to restart stop code: PAGE FAULT IN NONPAGED AREA
I have a problem when I started using a new graphics card gts 750ti restarts my computer and shows: (Your PC has run into a problem and needs to restart stop code: PAGE FAULT IN NONPAGED AREA does not always write PAGE FAULT IN NONPAGED AREA, but this is most often written, also This also shows when I restart my computer, when I remove the graphics from the computer I do not have this problem, I tried with a new graphics card, I still have a problem, do you have any solution? thanks
2018-12-09T08:18:33+00:00 -
2018-12-09T09:37:13+00:00 This is before the update https://1drv.ms/u/s!AszrGIm2cM6Cew9rXr1Dpl\_XZ4E and this is a new minidump after the update windows https://1drv.ms/u/s!AszrGIm2cM6CfAXDXvHLzN2u\_Co
2018-12-09T10:12:52+00:00 The dump was inconclusive. I think a clean install may be a good option. Would you like to go for a clean install?
2018-12-10T03:11:38+00:00 I was trying to install windows by deleting all the files, and that did not help me
2018-12-10T12:46:39+00:00 Were you able to clean install successfully?
