:( Your PC ran into a problem and needs to restart stop code: PAGE FAULT IN NONPAGED AREA
2018-12-08T04:47:30+00:00
I have a problem when I started using a new graphics card gts 750ti restarts my computer and shows: (Your PC has run into a problem and needs to restart stop code: PAGE FAULT IN NONPAGED AREA does not always write PAGE FAULT IN NONPAGED AREA, but this is most often written, also This also shows when I restart my computer, when I remove the graphics from the computer I do not have this problem, I tried with a new graphics card, I still have a problem, do you have any solution? thanks
    2018-12-08T06:58:55+00:00
    2018-12-08T06:59:13+00:00
    2018-12-08T07:09:19+00:00
    The only thing suspicious is IObit. Can you uninstall it and see whether it helps?
    2018-12-08T07:14:56+00:00
    I removed the iobit I think that it is not a problem, in the device manager just by clicking on the show hidden devices under the display adapter I noticed that the driver for the integrated graphic radeon was not deleted and I deleted it maybe that's the problem?
    2018-12-08T07:15:13+00:00
