I tried that about a month ago and did not help me
:( Your PC ran into a problem and needs to restart stop code: PAGE FAULT IN NONPAGED AREA
I have a problem when I started using a new graphics card gts 750ti restarts my computer and shows: (Your PC has run into a problem and needs to restart stop code: PAGE FAULT IN NONPAGED AREA does not always write PAGE FAULT IN NONPAGED AREA, but this is most often written, also This also shows when I restart my computer, when I remove the graphics from the computer I do not have this problem, I tried with a new graphics card, I still have a problem, do you have any solution? thanks
2018-12-10T19:50:11+00:00 -
2018-12-11T13:13:25+00:00 Try following. This is not on the basis of minidumps but on the basis of general experience.
- Download Intel:registered: Processor Diagnostic Tool and run it
https://downloadcenter.intel.com/download/19792...
- Run Prime95 - Stress Test Your CPU
https://www.tenforums.com/tutorials/16474-prime...
- Run Memtest for at least 8 passes (preferably during night before retiring to bed) to rule our memory problems
https://www.tenforums.com/tutorials/14201-memte...
- Run HDTUNE
- Run CHKDSK. To run CKHDSK -
Type cmd in Windows Start Search box
Right click on cmd.exe > Run As Administrator
Type following and Enter to fix problems on the C: drive while you're using it, and will use as much system resources as allowed so that it will run as quickly as possible. Say Y if it says that it will start CHKDSK at next restart
chkdsk c: /r /scan /perf
Disclaimer - This is a non-Microsoft website. The page appears to be providing accurate, safe information. Watch out for ads on the site that may advertise products frequently classified as a PUP (Potentially Unwanted Products). Thoroughly research any product advertised on the site before you decide to download and install it.
