Components are:
Motherboard asus m5a78l-m lx3
R memory Kingston Kingston DDR3 8GB 1866MHz HyperX Fury Black CL10
Power supply frontier 550W
Graphics card asus ge force gtx 750ti 2gb
Processor amd fx 6300
I have a problem when I started using a new graphics card gts 750ti restarts my computer and shows: (Your PC has run into a problem and needs to restart stop code: PAGE FAULT IN NONPAGED AREA does not always write PAGE FAULT IN NONPAGED AREA, but this is most often written, also This also shows when I restart my computer, when I remove the graphics from the computer I do not have this problem, I tried with a new graphics card, I still have a problem, do you have any solution? thanks
Components are:
We need log files(called dump files) that tell us what lead to crash.
Please share them with us for a better analysis of the problem. Instructions can be found here:
https://answers.microsoft.com/en-us/windows/for...
Please let us know if you need any assistance about posting dump files.
This is the link of the dump file https://1drv.ms/u/s!AszrGIm2cM6Ccv6l9OTV2\_vSoKo
A. Analysis Results
CRITICAL_PROCESS_DIED (ef)
IMAGE_NAME: ntkrnlmp.exe
B. Third Party Drivers
None
C. Recommendations
The dumps are inconclusive. Bugcheck EF is generally due to hardware / driver / system service. Here, !process command gives svchost.exe as the service but this is a general service and this service can be driven to fault by many causes.
Type restore point in Cortana Search > Create a Restore point > Check whether against your drive, Protection is ON or not. If not ON, click Configure button below to Make it ON > Now press Create to create a restore point
Windows Key+R > Type eventvwr and Enter > See if any log corresponding to your date and time is there (Look under all entries under Windows Logs such as Application, Security...) > If yes, right click on that log > Save Selected Event > Zip all event files which correspond to your event, upload them to Onedrive and share the link here.
https://answers.microsoft.com/thread/bc609315-d...
https://www.tenforums.com/tutorials/5470-enable...
Disclaimer - This is a non-Microsoft website. The page appears to be providing accurate, safe information. Watch out for ads on the site that may advertise products frequently classified as a PUP (Potentially Unwanted Products). Thoroughly research any product advertised on the site before you decide to download and install it.
