Asus updated the latest nvidia drivers and hopefully this fixes the problem
Download from here:
https://www.asus.com/Laptops/ASUS-VivoBook-15-X510UN/HelpDesk_Download/
I am using Asus Vivobook S15 S510UN running windows 10 1809[OS build:17763.253], I have been facing regular DRIVER_POWER_STATE_FAILURE and VIDEO_DXGKRNL_FATAL_ERROR BSOD after windows 10 october update.
I tried different fixes mentioned in forums and even tried to many nvidia drivers from one mentioned in Asus website and also from nvidia website[Using DDU]. But till now i couldn't able to get past BSOD. So i thought sharing here.
Below you can find last 3 Mini dump file[and one Memory.DMP after latest crash], Msinfo32 and nirsoft driver view details. So any suggestions and solutions can be really helpful.
One drive link: https://1drv.ms/f/s!AvYJCaSRFtREjkZX2GvhTrPuYByt
Download from here:
does that solve it?
Hey Karthik, I am using the same machine as yours. And I have also been facing this issue. Is this issue been solved for you ?
Also, anyone tried out Windows 10 1909 ? Is the issue still present ?
Tried out 1909, bluescreens still happening to my Asus UX331UN. Started when I upgraded to Windows 1809 in May 2019
share the memory dump files for analysis.
.try to do clean installation of 1909.
