Missing display / toggle for adaptive brightness in windows update 1809
2019-01-11T08:00:54+00:00
When will be the next update to fix the problem of missing the toggle to turn off the adaptive brightness in windows update 1809? This is a big issue for me in work.  Waiting for your immediate answer.
I am Using Windows 10 64 bit and currently updated to build 1809 (latest)
Laptop: Acer Swift 3
Thank You!
    2019-09-11T16:34:43+00:00
    And LAST night there were 3 MORE big updates and the answer to your question is
    HELL YES!!!!!!!!!!!!!!!!!!!!!!!!!!.
    ALSO THE MUTANT APP ENTRY ON THE START MENU
    2019-09-13T22:57:05+00:00
    Thanks so much. I'm running Version 1903 (OS Build 18362) on an EliteBook 8460P with AMD dedicated graphics. This issues was driving me insane. The constant shifting in brightness really messed with my eyes and gave me headaches. I guess this might be a dedicated graphics issue more than a Windows OS issue but idk. Hopefully anyone reading this finds a solution.
    2019-09-14T11:07:07+00:00
    YES WINDOWS - PLEASE FIND A SOLUTION.
    Andt this started with 1809 almost 1 year ago - was FIXED and then RETURNED with 1903.
    BTW - supposedly adaptive brightness is gone. AND IF ppl tell you to roll back your driver - IT DOESNT HELP.
    Resetting ur laptop WONT HELP EITHER.
    Annoying as hell
    2019-09-16T01:36:13+00:00
    2019-09-16T01:39:12+00:00
    A friend had this issue today (September 16th, 2019) ... I managed to solve it by going to Nvidia control Panel, Display, Adjust Desktop color settings, and selecting "Use nvidia settings" and setting the brightness from there.
    People with Intel or AMD graphics may benefit from the respective parts of this post https://www.thewindowsclub.com/windows-10-adaptive-brightness-not-working
