Missing display / toggle for adaptive brightness in windows update 1809
2019-01-11T08:00:54+00:00
When will be the next update to fix the problem of missing the toggle to turn off the adaptive brightness in windows update 1809? This is a big issue for me in work.  Waiting for your immediate answer.
I am Using Windows 10 64 bit and currently updated to build 1809 (latest)
Laptop: Acer Swift 3
Thank You!
    2020-02-01T12:25:37+00:00
    Been there done that - many times. roll back too.
    that does NOT help.
    And your comment: "Dimmed display brightness, and Enable adaptive brightness."
    IS GONE SINCE 1809 - THAT'S THE ISSUE!!!!!!!!!!
    2020-02-01T13:49:00+00:00
    So frustrating having a new computer and having this annoying issue
    2020-02-20T00:39:29+00:00
    Have you installed the "intel graphics command center" from the windows store? There is an adaptive brightness toggle inside, for battery and plugged in, that's where I found it on mine, even though I have a dedicated 2070 in my laptop, in desktop mode it switches to the intel integrated gpu. Please let me know if this helps anyone.
    2020-02-20T02:10:13+00:00
    My computer doesnt have intel
    2020-02-20T02:10:43+00:00
    My computer doesnt use intel
