Missing display / toggle for adaptive brightness in windows update 1809
2019-01-11T08:00:54+00:00
When will be the next update to fix the problem of missing the toggle to turn off the adaptive brightness in windows update 1809? This is a big issue for me in work.  Waiting for your immediate answer.
I am Using Windows 10 64 bit and currently updated to build 1809 (latest)
Laptop: Acer Swift 3
Thank You!
    2019-01-11T08:07:49+00:00
    Are you talking about the Night light settings?
    If so go Settings, System, Display.
    Also you can right click on the desktop nd pick Display settings.
    To help us to help you and to properly get answers to your post you should include some minimum information.
    1.  Device type. ie Desktop, Laptop, Tablet, Surface, Phone
    2.  Who made it and model, RAM size, HDD size. If home built what type motherboard, Intel, AMD, other
    3.  OS type, Home, Pro, Enterprise, 32 bit, 64 bit, etc
    4.  Current build.  Hit the WIN key, type winver, hit Enter.
    2019-01-11T08:14:33+00:00
    No, Even it is in 100 % brightness, Still, the screen is dim and found out that the toggle to turn off the adaptive brightness is missing after the windows update 1809. I'm not the only one who experiences these bugs. Also, my other workmate
    2019-01-11T08:21:48+00:00
    Currently using:
    Acer Swift 3, 12gb RAM, 1TB HDD
    Windows 10 64 bit, currently updated to build 1809 (latest)
    Hoping for your feedback. I know, you already knew that this bug/error is currently a hot topic after your Windows update build 1809
    2019-01-11T08:24:25+00:00
    What is an Acer Swift, desktop or laptop?
    1809 is the version not the build.
    2019-01-11T08:30:56+00:00
    I'm using Laptop Acer Swift 3. And thanks for the correction Sir, appreciated.
    I just updated the version yesterday because it is available in the windows update. Then after it was installed and restarted the laptop. Brightness became Dim even it is in 100 percent. And found out that adaptive brightness was missing in the display in the advanced settings in the battery. I search in the google and also found out that it is also the problem of the others who updated their version of Windows. So, I wanted to ask, when is the possible release of updates to fix this concern?
    Thank You!
