Why is there no "troubleshoot hardware & devices" in 1809 update?
2019-01-01T10:13:30+00:00
I have looked everywhere in settings & control panel, & there is no longer a troubleshooter for hardware & devices. All of the other troubleshoot options are still listed , & there is no "view all." In 1803 I could access it in " update & security" then chose "troubleshoot" & it was the 4th one listed under "find & fix other problems" where "keyboard" is now. Unless Microsoft will come up with a fix, I guess the only solution is to go back to 1803?
2019-01-02T05:27:14+00:00
Thank you for writing to Microsoft Community Forums.
Please note that Hardware and Device troubleshooter was removed from Windows 10 starting from the build version 1809. The Hardware & Devices troubleshooter had the lowest daily usage was usually run in tandem with other troubleshooters, therefore it was determined it was no longer needed and specific troubleshooters should be used instead (i.e. Bluetooth, audio, etc.).
Hope it helps.
64 additional answers
    2020-06-05T08:40:04+00:00
    YES, PLEASE- restore the troubleshooter!!! Take a survey on how many people want it back...
    2020-06-16T10:08:59+00:00
    Hope it helps.
    It inspired me a lot...
    I'll just asked my boss to remove the fire escape ladders from the office wall.
    They 've been never used.
    Fine regards,
    Ruth
    2020-06-16T10:21:48+00:00
    Great reply MS. Ruth!
    2020-07-04T18:37:20+00:00
    My safely remove USB icon does not always appear when I have a USB drive inserted and I cannot eject my USB. I have the option turned ON in Settings, but nothing helps get the icon back. Sometimes if I reboot it will appear. Without a troubleshooter I don't know how to fix the issue. I don't want to reboot my computer every time that I need to eject a USB.
