Why is there no "troubleshoot hardware & devices" in 1809 update?
2019-01-01T10:13:30+00:00
I have looked everywhere in settings & control panel, & there is no longer a troubleshooter for hardware & devices. All of the other troubleshoot options are still listed , & there is no "view all." In 1803 I could access it in " update & security" then chose "troubleshoot" & it was the 4th one listed under "find & fix other problems" where "keyboard" is now. Unless Microsoft will come up with a fix, I guess the only solution is to go back to 1803?
2019-01-02T05:27:14+00:00
Thank you for writing to Microsoft Community Forums.
Please note that Hardware and Device troubleshooter was removed from Windows 10 starting from the build version 1809. The Hardware & Devices troubleshooter had the lowest daily usage was usually run in tandem with other troubleshooters, therefore it was determined it was no longer needed and specific troubleshooters should be used instead (i.e. Bluetooth, audio, etc.).
Hope it helps.
64 additional answers
    2019-12-30T09:12:00+00:00
    the trouble shooter has been hidden
    1 open command prompt and run as admin
    2  copy and paste>> msdt.exe -id DeviceDiagnostic click enter
    3 WOOHOO! your device troubleshooter :)
    2020-01-22T13:19:12+00:00
    So what do you click on to Troubleshoot the Fingerprint Scanner that doesn't work with Windows 10?  All instructions I can find is to click on the Hardware and Devices.  It doesn't exist and I don't see what appropriate setting to click on.
    2020-04-10T12:49:18+00:00
    it will ask for a pass key ? i want to troubleshoot my USB 3.0 port
    2020-04-10T12:52:44+00:00
    Did Anyone Find a Fix For USB 3.0 ports I go to Device Manager and none of them Have the Exclamation Mark But Still Not Working Please Help
