This error usually comes up when there is a problem with the store on the Microsoft side. Usually the problem is resolved in a few days, please do not do anything with your phone, router or any other piece of equipment, no resets or reinstallations will make any difference and you may lose apps which are no longer available in the store. The solution can come only from MS and the only thing you can do is wait, no matter how frustrating it is.
Error 805a0193 on WP8.1 devices when downloading/updating apps from the Store - NOW RESOLVED
I recently bought a Nokia Lumina 640 because i want to get some windows phone games for achievents. The first thing i try and download gives me this error.
I have searched and searched and i cant find a definitive answer on what the issue is and how to resolve it. It seems to be some error with my network, but what error? Is it a port thing? What ports does it need?
I did the steps the microsoft website suggests, which were to: manually change my time, manually sync my email, make sure to update my microsoft account, and finally, to reset my phone. None of that worked so i am looking for real answers.
526 additional answers
RedSpook-9082 4,765 Reputation points Volunteer Moderator2018-12-10T21:21:34+00:00 i try everything to solve,result-0,microsoft say upgrade to windows10 ,but how when apps do not works
You can use the OTC updater tool which you can download to PC at the following link:
https://www.microsoft.com/en-us/download/details.aspx?id=56726
This is software for PC so no point in opening this link from your phone.
Please read the readme file before proceeding.
RedSpook-9082 4,765 Reputation points Volunteer Moderator2018-12-10T21:28:05+00:00 And I want a definitive answer to the question - Why can't I download apps and what is error code 805a0193?
You cannot download apps because there is a problem with the Store servers when accessed from a WP8.1 devices. This error code means there is a problem with the connection to a server.
Also if support had ended a year ago, why did I receive a critical update that shafted my phone..
Because when you got the phone it was not running the latest available firmware version for it. This remains available even after end of support even though it was originally released before that.
2018-12-10T21:45:51+00:00 Surprise! I guess that Windows Phone is a little more popular than anybody realized. I feel for you but there is no point getting 100 email notifications for something you and I have both figured out is a) no longer supported my Microsoft and b) Whatsapp and a couple other apps mentioned should honestly have their own sources of updating.
I would urge everyone to look for such a thing from these providers in the first place. I realize that you really don't want to buy a new phone and that you feel betrayed, but then again you were told all of this a long time ago and thought it was possible a joke.
I'm not hanging around at this point, I can't help you, I don't even own a cellphone, it's too expensive for me and nothing I know from using computers since the late 1970s is of any use here.
I wish you luck, surrender or both.
2018-12-10T21:48:50+00:00 This error usually comes up when there is a problem with the store on the Microsoft side. Usually the problem is resolved in a few days, please do not do anything with your phone, router or any other piece of equipment, no resets or reinstallations will make any difference and you may lose apps which are no longer available in the store. The solution can come only from MS and the only thing you can do is wait, no matter how frustrating it is.
Thank you for advice sir.we still wondering if there is no solution from Microsoft after 5days without updating or installing apps from store
Thank you.
