Error 805a0193 on WP8.1 devices when downloading/updating apps from the Store - NOW RESOLVED
2018-12-07T12:38:51+00:00
I recently bought a Nokia Lumina 640 because i want to get some windows phone games for achievents. The first thing i try and download gives me this error.
I have searched and searched and i cant find a definitive answer on what the issue is and how to resolve it. It seems to be some error with my network, but what error? Is it a port thing? What ports does it need?
I did the steps the microsoft website suggests, which were to: manually change my time, manually sync my email, make sure to update my microsoft account, and finally, to reset my phone. None of that worked so i am looking for real answers.
RedSpook-9082 4,765 Reputation points Volunteer Moderator
2018-12-07T19:08:28+00:00
This error usually comes up when there is a problem with the store on the Microsoft side. Usually the problem is resolved in a few days, please do not do anything with your phone, router or any other piece of equipment, no resets or reinstallations will make any difference and you may lose apps which are no longer available in the store. The solution can come only from MS and the only thing you can do is wait, no matter how frustrating it is.
526 additional answers
    2018-12-10T19:52:22+00:00
    i try everything to solve,result-0,microsoft say upgrade to windows10 ,but how when apps do not works,thanks microsoft for nothing,you say wait they solve it-when,they did not say nothing about 805a0193 error,and now we wait for nothing
    2018-12-10T20:21:13+00:00
    Hello 93tid,
    I don’t know if you are in any way related to Microsoft Support.
    The number of people with this problem does not stop growing in the last few days.
    In addition to the usual WhatsApp update that doesn’t install, there is an additional issue that everyone I found is having: when we try to access our list of apps in the Microsoft Store we get that same error.
    So far, I was not able to find any support document from Microsoft that helps in anyway.
    When you say that this situation usually take a few days to be repaired, it’s that based on you personal experience or some Microsoft Policy?
  3. Deleted
    2018-12-10T21:21:14+00:00
    Опять не работает магазин. Выдаёт ошибку 805a0193. Как это исправить?
