Error 805a0193 on WP8.1 devices when downloading/updating apps from the Store - NOW RESOLVED
2018-12-07T12:38:51+00:00
I recently bought a Nokia Lumina 640 because i want to get some windows phone games for achievents. The first thing i try and download gives me this error.
I have searched and searched and i cant find a definitive answer on what the issue is and how to resolve it. It seems to be some error with my network, but what error? Is it a port thing? What ports does it need?
I did the steps the microsoft website suggests, which were to: manually change my time, manually sync my email, make sure to update my microsoft account, and finally, to reset my phone. None of that worked so i am looking for real answers.
RedSpook-9082 4,765 Reputation points Volunteer Moderator
2018-12-07T19:08:28+00:00
This error usually comes up when there is a problem with the store on the Microsoft side. Usually the problem is resolved in a few days, please do not do anything with your phone, router or any other piece of equipment, no resets or reinstallations will make any difference and you may lose apps which are no longer available in the store. The solution can come only from MS and the only thing you can do is wait, no matter how frustrating it is.
526 additional answers
    2018-12-09T18:14:17+00:00
    ... I change to Android.
    2018-12-09T18:32:18+00:00
    I have 1 or two questions, based on what I know from using PCs since the mid 1980s, and before I'm dismissed I want you to try it or at least explain it to me without being disingenuous as I'm only trying to help.
    Did you all have an update to your OS recently?
    Can you roll back or restore to a previous state?
    Is it possible that the apps you downloaded weren't installing because the HASH wasn't correct?
    Think about it and report back. The worst that can happen is that I'm not on the right track but you've been at this for 3 days to the point of abject paranoia and conspiracy theories and you yourselves don't understand any better than I do. There is really nothing to lose at this point.
    And correct me if I'm wrong, you can still make cellphone calls with these phones?
    If so, that's what they do, they just can't do tricks for a while. It's a weekend, it usually takes until the new week for Microsoft to get on things in earnest. These guys like time off too and it's not like some virus is threatening the world. Have some more patience...when I was younger and only had one PC at a time a breakdown would require me to go to the library (limited time and capabilities) until I could fix it. That is why I have 2 or more, backup. But you can call, and Whatsapp works on PCs too, doesn't it?
    Ever had a car in the shop for a long time? You get a rental or you walk or carpool/take public transit. Same thing.
    2018-12-09T18:54:24+00:00
    Hi!
    I have an issue with error code 805a0193, occurred when i try to download apps from windows store.
    I have all the ways possible like Hard Reset, Soft Reset, Turning off the Automatic Time update, Changing the Time, Region, Restarting the Device multiple times, Changing the Wi-Fi network, Network settings and so on..
    I didn't find any solution. None of the above is helpful. It's really irritating. Could you please solve this issue. Please give a possible and accurate solution to solve this. I really fed up with this thing. Please make is as soon as possible.
    Thank You in Advance.
    2018-12-09T19:39:06+00:00
    Yes R.prasad.C i have same problem. I from indonesia.
