This error usually comes up when there is a problem with the store on the Microsoft side. Usually the problem is resolved in a few days, please do not do anything with your phone, router or any other piece of equipment, no resets or reinstallations will make any difference and you may lose apps which are no longer available in the store. The solution can come only from MS and the only thing you can do is wait, no matter how frustrating it is.
Error 805a0193 on WP8.1 devices when downloading/updating apps from the Store - NOW RESOLVED
I recently bought a Nokia Lumina 640 because i want to get some windows phone games for achievents. The first thing i try and download gives me this error.
I have searched and searched and i cant find a definitive answer on what the issue is and how to resolve it. It seems to be some error with my network, but what error? Is it a port thing? What ports does it need?
I did the steps the microsoft website suggests, which were to: manually change my time, manually sync my email, make sure to update my microsoft account, and finally, to reset my phone. None of that worked so i am looking for real answers.
526 additional answers
2018-12-09T10:00:10+00:00 I have problems to any app store installed in Lumia535
2018-12-09T10:09:09+00:00 Helping to create a DDOS attack WITH TELEPHONES RESECTED AT INITIAL FARM STATUS ?
Your guess is as good as mine. All of my phones are connected to the wall jacks.
At any rate, this error code is rather anonymous but well documented over at least 7 years if you use your favorite search engine. Having a worldwide fit over it didn't solve it then either. I just watched a You Tube video where some guy unboxed a 2016 Windows Phone model yet he never did seem to follow up on his experiences with it, other than it took more than two and a half hours to finish updating and had some decent functionality but that Microsoft was only making bug patches and not much in the way of a real update? Is that what I got from it?
As I told you earlier, this isn't 'official support', the piano player needn't be shot if they don't know any Shubert. There are still 12 notes in the western chromatic scale. Do offer your theories, that's how problems are solved here. It's no competition.
2018-12-09T10:14:43+00:00 please help. I am also receiving error code 805a0193 . Whatsapp update required attention and this is the code I received. I uninstalled the app but still receive this code after trying to reinstall. I am currently in a location with no mobile signal, so whatsapp over WiFi is my only communication means at the moment. I have a Nokia Lumina 635
2018-12-09T10:22:01+00:00 Did hard resetting thrice. Now all the apps are gone. Try installing apps again with an error 805a0193. It's been more than 72 hours now.
