This error usually comes up when there is a problem with the store on the Microsoft side. Usually the problem is resolved in a few days, please do not do anything with your phone, router or any other piece of equipment, no resets or reinstallations will make any difference and you may lose apps which are no longer available in the store. The solution can come only from MS and the only thing you can do is wait, no matter how frustrating it is.
Error 805a0193 on WP8.1 devices when downloading/updating apps from the Store - NOW RESOLVED
I recently bought a Nokia Lumina 640 because i want to get some windows phone games for achievents. The first thing i try and download gives me this error.
I have searched and searched and i cant find a definitive answer on what the issue is and how to resolve it. It seems to be some error with my network, but what error? Is it a port thing? What ports does it need?
I did the steps the microsoft website suggests, which were to: manually change my time, manually sync my email, make sure to update my microsoft account, and finally, to reset my phone. None of that worked so i am looking for real answers.
526 additional answers
2018-12-09T06:43:11+00:00 Same problem
2018-12-09T06:48:28+00:00 Bueno. Eso es, me borraron un post por haber dicho quien era el verdadero culpable de lo que ha occurrido y por decir que dejen de confundir la gente con remedios publicados en 2015 que no funcionan. No se en U.S.A. , pero en Europa si abandona un producto antes de los 10 años pueden persiguirlo por la ley. Eso es lo que tendriamos que hacer, NUNCA MAS UN PRODUCTO M$ VENDIDO Y ABANDONADO EN SEGUIDA A SU MUERTE, y todo eso sin explicacion alguna. Es una verguenza como se permiten de tratar sus clientes.
2018-12-09T07:13:01+00:00 error code 805a0139 while downloading aaps through windows 8.1 phone
2018-12-09T07:21:23+00:00 i always get the error code 805a0193 when i try to update whatsapp or get an app from the store
same here in india
