Lenovo 100s ideapad Bitlocker problem after Windows update Nov 2018.
2018-11-09T16:40:00+00:00
My Lenovo 100s got a Microsoft update on 2/11/18. Since restarting I get the bitlocker blue screen asking me to enter the recovery. I never set one up, was never asked to set one up, so don't have one. Been backwards and forwards with Lenovo, who say they are working on the problem and have now said it is a problem for Microsoft to sort out. Contacted Microsoft who have said it is a hardware problem for Lenovo to sort. Please can someone just help to sort it out.
2018-12-10T21:21:26+00:00
re the issue with Lenovo 100s and bit locker having been onto Lenovo and Microsoft to get issue resolved
first speaking with LENOVO they confirmed it is a Microsoft issue 100s Ideapad  DOES NOT HAVE TPM CHIP INSTALLED NOR IS THE HARD DRIVE PARTIONED  OR A SEPERATE BOOT OPTION IF YOU READ MICROSOFT OWN CRITERIA  for bit locker to be enabled THE MACHINE NEEDS THESE also as bit locker is Microsoft
not LENOVO . Having now spoken to a Microsoft agent in the U S A he now agrees that it is their issue
having pointed out their own criteria for bitlocker  he agreed beyond his pay grade and would force it up the line
I pointed out also two days before the update KB4462919 within my Microsoft account where you are supposed
to find this key my setting was off it now shows on not changed by me so why cannot the Microsoft accounts be rest to off by default like the update did earlier in year .I have written in disgust to Microsoft AS THIS IS NOW THE SECOND TIME UPDATES HAVE CAUSED ISSUES WITH LAPTOPS WITHIN THE FAMILY AND WE NEED ANSWERI AGREE CORPARTIONS NEED BIT LOCKER I DONT
99 additional answers
    2018-12-24T22:55:58+00:00
    HI JULIAlonzo
    If you can read posts by myself and paulw656 you will be able to see we are very active  in trying to get our laptops up and running could you reply to this and tell me your  full model code and serial number  and whether you can see all the posts
    regards brrpage
    2018-12-29T04:06:34+00:00
    Hi Beverley I just opened my laptop to the same issue, did the last fix work for you at all?
    What a mess, I also own a Dell and now scared to even open it, in case it updates :-(
  3. Deleted
    2019-01-04T09:51:36+00:00
    hi paul w656
    just to let you know have been again onto Microsoft uk for about 3 hours trying to get a resolve to issue went round in circles have now contacted Microsoft head office USA to see if I can get issue solved  LENOVO still say all down to MICROSOFT AND ARE WAITING FOR A PATCH
    how this will work on a
    locked machine with no other way to boot into windows have now tried everything suggested by both parties nothing works for me or the others round me
    on a separate thing if you now go into your MICROSOFT ACCOUNT THAT IS LINKED TO MACHINE IT HAS ALL CHANGED FROM 28/11/2018
    you used to have a status bar that has now gone
    have you had any luck your end
    regards brrpage
