Accidentally Uninstalled Biometric using Device Manager and its not coming back
2019-01-10T04:37:08+00:00
I seem to have permanently deleted the "biometric devices" category in the Device Manger. Windows Hello using a biometric device no longer works.
I have a home built desktop with a Mouse Cm-01a Window Hello camera. It was working very well for about a year. Some combination of the 1809 update and new AMD Graphics Card Drivers stopped it from working consistently.
I began trying to roll back graphics card drivers and do other troubleshooting. I even performed a recovery and it did not solve the issue. I read that I could uninstall the camera and have Windows reinstall the drivers. When this didn't work, I attempted to uninstall biometric devices and have it reinstall the divers. Unfortunately this category has never returned.
Now my Window Hello setting in Sign-in options says "Face and fingerprint recognition are not available on this device".
I have tried a lot of the steps you would see from other troubleshooting sites (edit group policy settings, restart the Windows Biometric Service), but no luck.
I'm at my wits end here. I would rather not have to do another restore (that state wasn't working perfectly well as it was). Perhaps I have to do a Repair Install. Let me know if I have any other options (or if I just need to bite the bullet). Thanks!
Here are some system stats:
Processor: Intel i5-4690
RAM 16 GB
OS: Windows 10 Pro
Version: 1809
Build: 17763.253 (I am in the release preview track)
GPU: Radeon RX 580 Series (XFX brand)
Radeon Software Version: 18.40.21.06
Edit: Some of the responses have asked that I contact the manufacturer. Unfortunately, that would be me since this is a home-built desktop. I will see if I can find anything through Intel or ASRock (motherboard manufacturer).
Windows for home | Windows 10 | Windows Hello, lock screen and sign-in
    2021-07-17T19:05:24+00:00
    I don't know about what Thunderbolt says. He appears very knowledgeable. All I can stand behind is what I posted as my Fix, above on June 20, 2021. THANKS!! E L
    2021-09-01T13:51:53+00:00
    You have no idea how much I appreciate this fix. Have tried all other fixes found elsewhere and this is the one that got my biometric drivers installed again. Thank you so much!
    2021-09-21T07:18:32+00:00
    THANK YOU SO MUCH! this is the only comment that fixed the biometric driver that i accidentally uninstalled! however, windows hello face still crashes when I try to set it up. Still, thank you for bringing back the lost driver!
    2021-09-26T23:51:52+00:00
    HI
    if you figure out how to stop crash windows hello setup,then tell us to know
    thanks
