I don't know about what Thunderbolt says. He appears very knowledgeable. All I can stand behind is what I posted as my Fix, above on June 20, 2021. THANKS!! E L
Accidentally Uninstalled Biometric using Device Manager and its not coming back
I seem to have permanently deleted the "biometric devices" category in the Device Manger. Windows Hello using a biometric device no longer works.
I have a home built desktop with a Mouse Cm-01a Window Hello camera. It was working very well for about a year. Some combination of the 1809 update and new AMD Graphics Card Drivers stopped it from working consistently.
I began trying to roll back graphics card drivers and do other troubleshooting. I even performed a recovery and it did not solve the issue. I read that I could uninstall the camera and have Windows reinstall the drivers. When this didn't work, I attempted to uninstall biometric devices and have it reinstall the divers. Unfortunately this category has never returned.
Now my Window Hello setting in Sign-in options says "Face and fingerprint recognition are not available on this device".
I have tried a lot of the steps you would see from other troubleshooting sites (edit group policy settings, restart the Windows Biometric Service), but no luck.
I'm at my wits end here. I would rather not have to do another restore (that state wasn't working perfectly well as it was). Perhaps I have to do a Repair Install. Let me know if I have any other options (or if I just need to bite the bullet). Thanks!
Here are some system stats:
Processor: Intel i5-4690
RAM 16 GB
OS: Windows 10 Pro
Version: 1809
Build: 17763.253 (I am in the release preview track)
GPU: Radeon RX 580 Series (XFX brand)
Radeon Software Version: 18.40.21.06
Edit: Some of the responses have asked that I contact the manufacturer. Unfortunately, that would be me since this is a home-built desktop. I will see if I can find anything through Intel or ASRock (motherboard manufacturer).
Windows for home | Windows 10 | Windows Hello, lock screen and sign-in
2021-07-17T19:05:24+00:00 -
2021-09-01T13:51:53+00:00 You have no idea how much I appreciate this fix. Have tried all other fixes found elsewhere and this is the one that got my biometric drivers installed again. Thank you so much!
2021-09-21T07:18:32+00:00 THANK YOU SO MUCH! this is the only comment that fixed the biometric driver that i accidentally uninstalled! however, windows hello face still crashes when I try to set it up. Still, thank you for bringing back the lost driver!
2021-09-26T23:51:52+00:00 THANK YOU SO MUCH! this is the only comment that fixed the biometric driver that i accidentally uninstalled! however, windows hello face still crashes when I try to set it up. Still, thank you for bringing back the lost driver!
HI
if you figure out how to stop crash windows hello setup,then tell us to know
thanks
