Everyone, this worked. You just have to do the process using PowerShell. Thank you leopitcher.
Accidentally Uninstalled Biometric using Device Manager and its not coming back
I seem to have permanently deleted the "biometric devices" category in the Device Manger. Windows Hello using a biometric device no longer works.
I have a home built desktop with a Mouse Cm-01a Window Hello camera. It was working very well for about a year. Some combination of the 1809 update and new AMD Graphics Card Drivers stopped it from working consistently.
I began trying to roll back graphics card drivers and do other troubleshooting. I even performed a recovery and it did not solve the issue. I read that I could uninstall the camera and have Windows reinstall the drivers. When this didn't work, I attempted to uninstall biometric devices and have it reinstall the divers. Unfortunately this category has never returned.
Now my Window Hello setting in Sign-in options says "Face and fingerprint recognition are not available on this device".
I have tried a lot of the steps you would see from other troubleshooting sites (edit group policy settings, restart the Windows Biometric Service), but no luck.
I'm at my wits end here. I would rather not have to do another restore (that state wasn't working perfectly well as it was). Perhaps I have to do a Repair Install. Let me know if I have any other options (or if I just need to bite the bullet). Thanks!
Here are some system stats:
Processor: Intel i5-4690
RAM 16 GB
OS: Windows 10 Pro
Version: 1809
Build: 17763.253 (I am in the release preview track)
GPU: Radeon RX 580 Series (XFX brand)
Radeon Software Version: 18.40.21.06
Edit: Some of the responses have asked that I contact the manufacturer. Unfortunately, that would be me since this is a home-built desktop. I will see if I can find anything through Intel or ASRock (motherboard manufacturer).
Windows for home | Windows 10 | Windows Hello, lock screen and sign-in
2021-02-06T01:55:34+00:00 -
2021-03-01T11:08:31+00:00 Someone above mentioned to go under C:\Windows\System32\WinBioPlugIns\FaceDriver and reinstall the driver by right-clicking on HelloFace.inf and click install. That did not work for me....
What worked for me was
- launch powershell as admin
- cd into the C:\Windows\System32\WinBioPlugIns\FaceDriver directory
- use PNPUtil to first remove the HelloFace driver. Command: pnputil.exe /delete-driver .\HelloFace.inf
- now use PNPUtil to install the driver. Command: pnputil.exe /add-driver .\HelloFace.inf /install
- the biometric driver should now show up in device manager
Let me know if this helps!
This really works! I have tried the previous about install hello.inf but did not work. But this did work for me!!! Thank you so much!
2021-03-03T05:59:11+00:00 Hi! I did that but when I click install it says that it couldn't find the file. I'm not sure what else to do. It will not reinstall.
2021-03-18T07:51:03+00:00 Absolutlely worked nothing else would this is Brilliant Thanks Very Much. I deleted the device driver (DOH), install from inf would say successful but no go after multiple restarts etc THIS IS THE ANSWER!!
2021-03-24T20:09:13+00:00 You, sir, are a genius! This worked 100%!! Thank You!!
