Accidentally Uninstalled Biometric using Device Manager and its not coming back
2019-01-10T04:37:08+00:00
I seem to have permanently deleted the "biometric devices" category in the Device Manger. Windows Hello using a biometric device no longer works.
I have a home built desktop with a Mouse Cm-01a Window Hello camera. It was working very well for about a year. Some combination of the 1809 update and new AMD Graphics Card Drivers stopped it from working consistently.
I began trying to roll back graphics card drivers and do other troubleshooting. I even performed a recovery and it did not solve the issue. I read that I could uninstall the camera and have Windows reinstall the drivers. When this didn't work, I attempted to uninstall biometric devices and have it reinstall the divers. Unfortunately this category has never returned.
Now my Window Hello setting in Sign-in options says "Face and fingerprint recognition are not available on this device".
I have tried a lot of the steps you would see from other troubleshooting sites (edit group policy settings, restart the Windows Biometric Service), but no luck.
I'm at my wits end here. I would rather not have to do another restore (that state wasn't working perfectly well as it was). Perhaps I have to do a Repair Install. Let me know if I have any other options (or if I just need to bite the bullet). Thanks!
Here are some system stats:
Processor: Intel i5-4690
RAM 16 GB
OS: Windows 10 Pro
Version: 1809
Build: 17763.253 (I am in the release preview track)
GPU: Radeon RX 580 Series (XFX brand)
Radeon Software Version: 18.40.21.06
Edit: Some of the responses have asked that I contact the manufacturer. Unfortunately, that would be me since this is a home-built desktop. I will see if I can find anything through Intel or ASRock (motherboard manufacturer).
Windows for home | Windows 10 | Windows Hello, lock screen and sign-in
    2020-12-06T19:40:47+00:00
    This works! Thanks a lot!
    2020-12-31T16:25:15+00:00
    If the prior items do not work (as they did not work for me), do this which worked.
    I worked on this for 3 days before I found a solution that worked for me. I tried all of the above first.
    Go to Settings>Update and Security>View update history>Uninstall Updates>then uninstall every update that is not a security patch.
    restart
    Then go and download the newest windows 10 update from the below:
    https://www.microsoft.com/en-us/software-download/windows10
    Install!
    You will thank me later.
    I have an
    HP Spectre x360 - 13t-aw000
    just in case anyone is googling that as well.
    2021-01-06T06:13:03+00:00
    Thank you - this is a quick and easy fix!  Just uninstalled my last Windows update (I think a November 2020 update) and immediately downloaded the Windows 10 update as described.  Biometrics Devices was automatically reinstalled and Windows Hello Face immediately worked on restart.
    I have Surface Pro laptop.
    2021-01-20T21:36:39+00:00
    Thank you! This finally worked! I have automatic updates turned on, so I didn't have to download the newest update, as it did it (I assume) on restart.
    2021-01-22T07:25:07+00:00
    Hello LoganAiport, I will be able to help you with this problem you are facing. First of all, Open File Explorer and go to the following path, C:\Windows\System32\WinBioPlugins\FaceDriver. Then right click HelloFace.inf and click install. Then if needed, after install reboot your computer and see if it works.
