High Definition Audio Controller (Code: 10) Issue
2019-01-15T06:02:51+00:00
Motherboard: MSI B360M Gaming Plus
OS: Windows 10 Pro
List of things I've done:
Downloaded audio drivers from MSI website
Updated my BIOS
Uninstalled and Reinstalled the High Definition Audio Controller
cmd commands: sfc /scannow & DISM.exe /Online /Cleanup-image /Restorehealth
Completely removed all other audio drivers and installed Realtek audio drivers (Which for some reason never actually appear on device manager?)
I'd appreciate any help I could get.
It started happening out of the blue; I never downloaded anything.
    2020-03-26T08:15:29+00:00
    I can't believe it - I spent all day trying to figure out the solution to "No Input or Output Audio Devices" for Windows 10  after an update. I kept being told to reinstall drivers and nothing worked.
    Bizarrely, uninstalling my Sound Device from Device Manager as well as the HD Audio Controller and holding power for 50 seconds with the cord unplugged worked!
    2020-03-26T09:28:38+00:00
    That's exactly what I did and it worked!
    2020-03-30T05:38:39+00:00
    I tried many many things.
    Solution that finally worked for me (don't skip any steps):
    1. Open device manager and Uninstall High Definition Audio Controller.
    2. Shut down (not restart).
    3. Unplug the power cable.
    4. Press and hold down the power button for 60 seconds.
    5. Plugin and turn on the laptop.
    I made an account just to **** thank you. Dude I was stuck on this **** for a good 1-2 days. Legend!
    2020-03-30T10:15:45+00:00
    Thanks for the information
    Cheers!
    Kudabola
    2020-04-07T15:33:25+00:00
    FINALLY a solution that works, I can't believe it was that simple!
    I even reset my computer to factory settings because every solution i tried for the past 8 hours didn't work. The same issue persisted after the reset.
    I am still PISSED about it.
    Thank you so much for putting up this solution, you are a Godsend. Bless you!
