Thanks so much. I have been battling this problem for over a week. Your solution worked!
High Definition Audio Controller (Code: 10) Issue
Motherboard: MSI B360M Gaming Plus
OS: Windows 10 Pro
List of things I've done:
Downloaded audio drivers from MSI website
Updated my BIOS
Uninstalled and Reinstalled the High Definition Audio Controller
cmd commands: sfc /scannow & DISM.exe /Online /Cleanup-image /Restorehealth
Completely removed all other audio drivers and installed Realtek audio drivers (Which for some reason never actually appear on device manager?)
I'd appreciate any help I could get.
It started happening out of the blue; I never downloaded anything.
2019-11-18T00:58:28+00:00 -
2019-11-26T16:21:55+00:00 Many thanks, it works for me !!
2019-12-25T21:03:21+00:00 i restarted my pc and now the mouse is not appearing on the screen thx alot
2019-12-30T17:33:22+00:00 It works! Thank you very much!
I got the issue a while after an update. I tried many suggestions in vain. But your advice work like magic!
Thank you again!
2020-01-12T07:53:58+00:00 Thank you very much! You are the best!
