High Definition Audio Controller (Code: 10) Issue
2019-01-15T06:02:51+00:00
Motherboard: MSI B360M Gaming Plus
OS: Windows 10 Pro
List of things I've done:
Downloaded audio drivers from MSI website
Updated my BIOS
Uninstalled and Reinstalled the High Definition Audio Controller
cmd commands: sfc /scannow & DISM.exe /Online /Cleanup-image /Restorehealth
Completely removed all other audio drivers and installed Realtek audio drivers (Which for some reason never actually appear on device manager?)
I'd appreciate any help I could get.
It started happening out of the blue; I never downloaded anything.
    2020-12-05T14:26:44+00:00
    I tried many many things.
    Solution that finally worked for me (don't skip any steps):
    1. Open device manager and Uninstall High Definition Audio Controller.
    2. Shut down (not restart).
    3. Unplug the power cable.
    4. Press and hold down the power button for 60 seconds.
    5. Plugin and turn on the laptop.
    I had been at it for the past 24 hours. This is the only thing that worked.
    Many thanks
    2020-12-10T05:13:30+00:00
    I've spent hours trying to fix this. I was about to reimage my system and reinstall windows. Such an easy solution. Thank you so much sir! You've saved me a lot of time.
    2020-12-21T13:37:39+00:00
    If your notebook has switchable graphics, update intel video driver and the problematic driver will became Intel audio driver.
