I had the same problem. I had to click "Reconnect" and project to the display again, then click "Disconnect" on the banner. That cleared it. The banner itself seems buggy, and it doesn't seem to like it when you use the "Connect" button in notifications, as we've all been conditioned to do.
Remove Wireless Projection Banner from Desktop screen
is it possible remove the new "Wireless Projection Banner" introduced in 1809 or at the very least move it so that it does pop-up every time I touch a tab in my browser?
***Original title: Wireless Projection Banner***
Windows for home | Windows 10 | PC projection
2019-08-22T19:43:26+00:00 -
2019-08-26T17:09:27+00:00 Thanks for the suggestion. It would be a good one but I have not been able to get past the msg: must have admin permission. I'm set as admin and I own this Surface Pro. Any suggestions?
2019-08-26T17:20:40+00:00 Thanks so much, this worked for me
2019-08-30T11:52:24+00:00 I Pin the banner when I'm projecting to the screen to hide it, and I just click "Disconnect" when I'm done projecting. The banner goes away.
2019-08-30T16:24:20+00:00 Yes, but that does not solve the real issue. The banner is a nuisance while projecting. So glad I don't have to deal with it anymore!!!
