The simplest way to get it OFF once it's stuck.
Step 1: press CTRL + ALT + DELETE
Step 2: Select Task manager
Step 3: search for explorer.exe in the Process tab
Step 4: right-click > End process
Step 5: in Task Manager click File > Run
Step 6: explorer.exe - hit enter
Voila - the **** is gone.
