Transferring data from eMMC C: Drive to a Seagate Backup USB Drive - the computer won't boot without a Windows 10 USB stick
2018-12-03T14:46:47+00:00
I'm trying to recover data from an unbootable laptop with a eMMC drive. I can now see the drive and wish to copy it to my Seagate Backup Drive, but I have no mouse.
the Ctl + C & Ctrl + V from C: to Seagate do not operate. Also when I opened up te C: Drive it did not list all files :
How do I copy the C: Drive onto my Seagate Backup USB Drive?
And then how do I see the files that must be there but are not listed?
If you can answer in part I would be grateful.
    2019-01-03T20:44:52+00:00
    Yes, that UUI in C was a boot up USB.  I need to do another long think.
    2019-01-03T22:05:12+00:00
    I think that either the eMMC is not getting power, or it has failed...
    The only other thing I can suggest would be to check in the Bios of the machine and see if it appears there... Or if somehow it got turned off, which I don't think is possible...
    If it were a normal drive I would suggest checking the connection, but I am sure that it is soldered in... Not counting the difficulty of getting to it...
