Audio problem on Logitech Z Cinema after October Update
2018-10-03T21:26:38+00:00
After installing October Update on Windows 10 volume control is not working (using Logitech Z Cinema speakers through USB).
Driver update, restart explorer, restart Windows Audio service didn't help.
Any suggestion ?
    2018-11-15T01:11:22+00:00
    Thank you for your response.
    Thank you for writing to Microsoft Community Forums.
    I would suggest you to download the driver and restart your computer.
    Refer the Microsoft article to update the drivers
    Hope it helps.
    Let us know if you got the help you needed by clicking ‘Yes or No’.
    Harish
    Microsoft Community – Moderator
    2018-11-15T14:53:58+00:00
    Hope it helps.
    Harish
    I appreciate the reply but have you at least read through the entire thread? The only available driver from Logitech stopped working correctly after update 1803 no matter what I try and god knows I tried everything described here.
    2018-11-24T20:02:25+00:00
    Still need help.
    2018-11-30T13:16:10+00:00
    Up! Can anyone help?
    2018-12-01T23:55:14+00:00
    Same here. Did the update 1809 today, no USB sound now.
    I tried install/uninstall, clean install, name it, nothing works.
    Bravo MS...
