Audio problem on Logitech Z Cinema after October Update
2018-10-03T21:26:38+00:00
After installing October Update on Windows 10 volume control is not working (using Logitech Z Cinema speakers through USB).
Driver update, restart explorer, restart Windows Audio service didn't help.
Any suggestion ?
    2018-11-11T03:01:23+00:00
    Thank you for writing to Microsoft Community Forums.
    I would suggest you to follow below mentioned method and see if that helps.
    Method : Check the services in the background.
    1. Go to Search, type ‘Services.msc’, and go to Services.
    2. Find Windows Audio, right click on it, and go to Properties.
    3. Make sure that Startup type is set to Automatic.
    4. Click on Stop, and wait for the process to stop.
    5. Now, click to start once again.
    6. Restart your computer, and check if the issue is resolved.
    Hope it helps.
    Let us know if you got the help you needed by clicking ‘Yes or No’.
    Harish
    Microsoft Community – Moderator
    2018-11-11T03:43:43+00:00
    Windows Audio service is already set on automatic. However, I stopped it and started it again; rebooted the computer and still have the same problem. Volume is always on high and the volume control doesn't change the level at all. The volume control works correctly with the HDMI output and the analog output, but not with the USB output Z-Cinema speakers.
    2018-11-11T04:04:51+00:00
    Thank you for your response.
    Try to connect it to different port and restart your computer.
    Follow below mentioned steps and see if that helps.
    1. Press Windows Key + X on your keyboard and select Device Manager from the list.
    2. Find the problematic device and right click it. Choose Uninstall device from the menu.
    3. Uninstall Speaker Audio device from Audio inputs and outputs section and your audio device from Sound, video and game controllers section.
    4. Click on Scan for hardware changes icon or restart your PC to reinstall the drivers.
    5. Once your drivers are reinstalled, it should be working.
    Follow the Microsoft article to troubleshoot on sound problems in Windows 10.
    Hope it helps.
    Harish
    2018-11-11T04:46:06+00:00
    I did that, "Uninstall Speaker Audio device from Audio inputs and outputs section and your audio device from Sound, video and game controllers section.", and everythimg is still the same, even after reboot.
    I have Logitech driver installed, in device maanger now I can see that my speakers have name Z cinema with TruSurround HD, driver Microsoft 10.0.17763.1.
    Volume control is partly working, I can change the volume but it's not "linear" as it was before. At begining goes rapidly up, then slows down.
    Turning SRS on and off is still not working through remote controll, only in logitech app.
    2018-11-11T05:06:37+00:00
    As you said it is partly working now. I would suggest you to perform a clean boot and refer the Microsoft article under section ‘**How to determine what is causing the problem after you do a clean boot’**and ‘Reset the computer to start normally after clean boot troubleshooting’.
    Disclaimer: A ‘clean boot’ starts Windows with a minimal set of drivers and startup programs, so that you can determine whether a background program is interfering with your game or program. Your computer may temporarily lose some functionality while in a clean boot environment, however, that functionality will return when you reset the computer to start normally after you have finished your troubleshooting.
    Hope it helps.
    Harish
